Blu-ray-Player
Navigation:  Export a project
Blu-ray-Player
Call up the Video Wizard via Wizards. There you will find two options for burning a disc for the Blu-ray-Player.
1 Select medium
Blu-ray - If you have a Blu-ray burner and corresponding blanks, use this option. This will burn a Blu-ray directly.
AVCHD - If you have a DVD burner, you can burn in HD quality and insert the disc into the Blu-ray-Player. Select this option to create an AVCHD for your Blu-ray-Player.
Select the option that suits you and click Next.
Blu-ray and AVCHD in Video Wizard
Burn settings for Blu-ray
2 Settings for video and burner
Setting
Meaning
Burner
Under change... you can select another burner and reduce the burning speed.
Bitrate
The higher the bit rate, the more information is stored, thus the larger the file. Refer to the properties of the playback device. Check constant to burn at a constant rather than variable bit rate.
Smoother video through interlacing
Interlacing saves intermediate images so that certain image movements appear smoother. Should only be activated when outputting for tube TVs.
Correct TV borders
Image borders are added, this is worthwhile e.g. when playing on tube TVs.
Save generated video to
If you know that you want to burn the same video again, save the created video file. This will save you time the next time you burn.
do'nt burn, only create video
Select a location in the item above if you only want to create a video and not burn it (yet).
Click Next and then Create video to burn the AVCHD or Blu-ray.
