Save track list
Navigation:  Inserting sound and music
Save track list
Once you have added a set of songs to your project, you can export them as a track list and use them for other projects.
To do this, go to the Music button located at Toolbar. Click Background music in the menu on the right. Select the Track list icon (see screenshot) and click the Save track list command.
Save track list
Save track list
Now specify a name and a location for your track list. The track list will be saved as an asl file.
Save track list as
Save track list as
If you now create a new project, you can insert the track list into your project via Music / Background music / Import track list.
