Program settings
Navigation:  Settings
Program settings
The Program settings refer to the basic settings of the entire program and not to individual projects, which you can find under Project / Settings (more on this in the "Project settings" chapter).
Call up the Program settings via the Extras menu. Here you can, among other things, adjust the User interface to your preferences or set the behavior of the program to your system environment.
At the Program settings window at the bottom left, you will find the option to reset the program settings to the factory defaults with the clock icon.
1 Language
The AquaSoft Vision and Stages can be used in different languages. Select the desired language and confirm with OK. Afterwards a restart of the program is necessary.
2 Add files
Allows you to specify the insertion order and position.
If you add several files at the same time, specify in the Sort section  beforehand according to which options the files should be sorted.
You can sort files already inserted into the project under Edit / Sort.
3 User interface
Here you will find further setting options for the user interface. Deactivate the Tooltips if you do not want them to be displayed in the program interface.
Depending on whether you use AquaSoft Vision or Stages, you can choose from different themes when displaying.
Via Action on double-click you can set what happens when you double-click on an image in Timeline, Storyboard or Image list. The possible actions correspond to the menu items in the main menu of the program.
If you activate Synchronize controls, then an image that you select in the Timeline will also be selected in the Storyboard and vice versa. It can be useful to change the behavior, then each control has its own selection. It is then possible, for example, to move images from the Storyboard to different chapters in the image list without changing the other control in each case when selecting the images.
4 Confirmations
In AquaSoft Vision and Stages there are some dialogs and hint windows. You can activate or deactivate them here.
5 Automatic update
Every user who has purchased a full version has free access to updates after registering the license key. The updates can contain improvements for possibly existing errors or new program functions.
Set here the interval in which the application should check whether a new update is available. A connection to the Internet is required for the check.
6 User directories
User data directory: You can create your own templates, which are displayed in the Toolbox directory. These are stored in a folder that you can define yourself at this point. This has the advantage that you no longer have to search for your own templates if you want to archive them or pass them on.
Temporary directory: AquaSoft Vision briefly requires space for temporary files on the hard disk for certain operations. Here you specify the directory in which temporary files may be temporarily stored. Video creation may require a lot of disk space. If the temp directory does not provide enough space, you can specify another directory here that is located on a different disk.
Select your preferred directory using the folder icon. You can use the arrow symbol to replace the default directory. The eye symbol shows you the stored directory in the Windows Explorer.
7 Sound recording
You can use the Sound Wizard to record spoken comments about your images via a connected microphone. Define the settings for the recording here.
8 Default image settings
Determine here with which default settings image objects and text objects are to be inserted. You can set default values for your text options and default blending here.
In the AquaSoft Photo Vision, fewer options are available here.
More complex default settings can be implemented using your own objects.
9 Package management
Here you can see which program packages (e.g. Intelligent Templates) and extension packages are enabled or disabled in the program. You can use the checkmarks to turn them on and off. Restart the program to apply the changes to the program.
10 Sound system
The Sound system takes care of playing the music included in the project. By default, find best output mode automatically is set . If you have problems playing the music, select here Windows Multimedia and then restart AquaSoft Vision.
11 CD/DVD/BD burner
The detected CD/DVD/BD burners are displayed here. If no burner is installed or no external burner is connected, the two fields remain empty.
Select the burner to be used and set the burning speed. Please note that a high burning speed can result in poorer burning quality (depending on the type and brand of the blank disc, among other things). If you have problems reading the burned media, try a slower burning speed. If no burner is displayed, try a different interface.
12 Automatic backup
Specify here whether and how often backup copies should be created automatically while you are working on a project. Your original project will not be overwritten during this automatic backup. Under File / Restore you can call up an older status of your work.
13 Storyboard
Make settings for the Storyboard here.
14 Layout designer
You can make settings for the Layout designer here.
Under Objects simultaneously you define up to which number of objects are displayed simultaneously in the Layout designer. For complex collages, it may be necessary to increase this value. A high number of simultaneously displayed objects costs correspondingly more computing power and RAM.
Furthermore, you can specify whether you want to display the Paths and motion marks for selected objects only and central object handles.
In a submenu you can define more precisely how the grid should look like and how the objects should react to the grid. You can learn more about the grid in the "Layout designer" chapter.
15 Timeline
Define the settings for the Timeline here.
If you want to work very precisely, the "Exact (tight)" style is recommended, because it leaves no optical gaps for the discreet shadow between the objects.
Under Video thumbnails, specify how many thumbnails should be used to display video objects in the Timeline. For slower computers, we recommend "At the beginning and at the end", where the first and last video frames on the object are shown as thumbnails.
For Tracks in chapter, specify how many permanent tracks the start chapter should have, which you will find in the Timeline when you create a new project. With the value 0, no start chapter object is created.
If Show tooltips is activated, you will get hints about objects, e.g. duration, start time, filename, when you move the mouse over them.
If Use large placeholder tracks is checked, the note "Drag here to create new track" appears in the Timeline. This is for better orientation for inserting into new tracks. If the item is unchecked, only a minimized placeholder is visible.
Other objects can be used as a snap-in aid and/or the Timeline time scale.
Select your preferred behavior for the Playhead, especially for controlling the "Play from here (Playheadposition)".
Does not change on object selection: The Playhead always stays where you place it in the Timeline timescale.
Always jumps to the selected object: The Playhead places itself at the beginning of an object that you select in the Timeline.
Jumps to the selected object when live preview is not active: The Playhead only places itself at the beginning of an object that you select in the Timeline until you activate the Live preview.
16 Image list  VIDEO VISION   STAGES
Select here which information should be displayed in the Image list.
17 Hardware acceleration
Videos are decoded faster with suitable hardware. If you observe jerking in the inserted videos during playback or if you use an older graphics card, the hardware acceleration should be deactivated.
18 Remote control
Check the box in front of "Enable remote control" to control a presentation via app. Learn more in the chapter Using remote control or presenter.
