User interface selection
Navigation:  Settings
You can choose between the following eight skins for the user interface. When you start the program for the first time, the skin selection depends on the color mode of your Windows settings.
Dark
Medium dark
Medium light
Light
Midnight (Default for dark design)
Slate
Grayish blue
Light grayish blue (Default for light design)
You can change your selection at any time via Extras / Program settings / User interface. You can also decide whether the icons and symbols of the user interface should be displayed in color, monochrome or black respectively white depending on the skin color.
After making your selection, you will need to restart the software for the changes to take effect.
