Motion paths with text
Navigation:  Motion paths
Just as with images, you can also also have text moving along motion paths. In the chapter "Introduction to motion paths", you can discover how to create motion paths. You will need this knowhow in this chapter.
1 Insert objects
In the example below, the text is over an image. For this purpose, an Image object from the Toolbox was inserted into the Timeline or Image list. The text was entered into the text field in the Properties window on the Text tab. If you only want to add a motion path to a text without an image, use the Text object.
Entering a caption in the text box
2 Create a motion path
Text with motion path
Motion path of the text in the Layout designer
In order now to move the text, insert a new motion mark with the Plus icon. In the Layout designer position the markers to your liking. Then insert further motion marks with the squared plus icon and, in this way, create your motion path.
Settings for text object
When you have created your motion path there are further ways to adjust the text. You will find these in the properties window under th text tab.
Text block
The text remains horizontal and is guided straight along the path.
Individual letters
The letters are individually animated and stick to the path.
Rotating the text block
The complete text is rotated in relation to the run of the path.
Rotating letters
The letters move individually along the path, and stick to the path.
