Save custom image effect
Navigation:  Save custom settings
1 Create image effect
You can create extensive image effects in the Image editor. Of course, these can also be saved for use in later projects.
After you have created an effect in the Image editor, click the disk icon to save it under its own name.
Create or adjust image effect
2 Enter title
Enter name for image effect
A dialog for saving the image effect opens. Enter a suitable title here.
3 Image effect in the Toolbox
Custom image effect in the Toolbox
You can now find your image effect in the Toolbox under Image effects / Custom image effects under the name you entered in step 2.
