Burning a menu for the PC
Navigation:  Export a project > Menu Wizard > How to
Settings for PC menu
If you have created a menu, you can export it and burn it onto a CD or DVD with all the projects you have used it with.
This CD or DVD can be played back on any PC.
1 Load or create a new menu. Click on the left side of the Menu Wizard window, on the item Projects in the project tree.
2 Click on the PC menu tab. Insert your settings for PC export here
3 From the Window section, select of one of the predefined resolutions, or enter your own, custom resolution.
When burned, the menu will later be played back in the resolution that you specify here.
From the Display section activate Show button hints if you later wish to see the functions of a button when the mouse passes over it.
4 Click on the button TBr_Export .
Select PC menu
Select PC menu
5 Select the output format PC Menu and click Next.
Burn PC menu
Burn PC menu
6 Activate the checkbox Burn project and click on the Burner settings to select a burner and, if you like, adjust the burning speed.
Then insert a writable CD or DVD into your burner.
Uncheck the box to the left of the drop-down menu and click on the Next button.
7 If you have inserted a CD-RW, DVD + RW or DVD-RAM which already has data on it, you can click Yes when the Menu Wizard asks if you would like to delete this data.
Click Cancel if you want to cancel the export. If you want to use another medium, insert it now and click No.
After clicking on Yes, the Menu Wizard will delete your CD or DVD.
After the deletion is finished, click OK.
8 The Menu Wizard is now ready for export. Click on the Export project button.
9 After finishing the export, click OK.
