Exporting a menu to a directory
Navigation:  Export a project > Menu Wizard > How to
Settings for PC Menü
Once you have created a menu, you can export it with all the projects and images used to a folder and burn, archive or view it later.
1 Load or create a new menu. Click on the Project entry on the left side of the Menu Wizard window in the project tree.
2 Click on the PC menu tab. Here you can make settings for the export.
3 In the Window section, select one of the preset resolutions or enter your own resolution.
If you want to play back the menu later, the resolution set here will be used. Activate Show button hints if a hint about the function of a button is to be displayed later when the mouse is moved over it.
4 Click on the button TBr_Export.
Select PC menu
Select PC menu
5 Select the output format PC menu and click Next.
Copy project to a directory
6 Check the checkbox to the left of the drop-down list and uncheck the Burn project checkbox.
Select the Copy project to a directory entry from the drop-down list.
Click the Extended button.
Activate the Copy Player checkbox if you want to copy the Player for the menu in addition to your project.
Activate the Copy fonts checkbox if you also want to copy the fonts that your templates use.
Select a Target directory for the export and then click Next.
7 The Menu Wizard is now ready for export. Click on the Export project button.
8 After finishing the export, click OK.
