Archiving a menu
Navigation:  Export a project > Menu Wizard > How to
Archiving a menu
Settings for PC Menü
If you have created a menu, you can archive it. You can create a ZIP file of all projects and images you have used with the help of the export wizard.
1 Load or create a new menu. Click on the Project entry on the left side of the Menu Wizard window in the project tree.
2 Click on the PC menu tab. Here you can make settings for the export.
3 In the Window section, select one of the preset resolutions or enter your own resolution.
If you want to play back the menu later, the resolution set here will be used. Activate Show button hints if a hint about the function of a button is to be displayed later when the mouse is moved over it.
4 Click on the button TBr_Export.
Select PC menu
Select PC menu
5 Select the output format PC Menu and click Next.
Compress project (Zip)
6 Check the checkbox to the left of the drop-down list and uncheck the Burn project checkbox.
From the drop-down menu, select the item Compress project (Zip).
Click the Extended button and activate the checkbox Copy player if you wish the player for the menu to also be copied into the ZIP file. Activate the checkbox Copy fonts if you want the fonts that you use in your templates to also be copied into the ZIP file.
Enter a Archive file and click Next. The Menu Wizard will warn you if you have specified an existing ZIP file.
7 The Menu Wizard is now ready for export. Click on the Export project button.
8 After finishing the export, click OK.
