Keyboard layout
Navigation:  Program overview
Keyboard layout
In AquaSoft YouDesign you can also access some functions via the keyboard. Many keyboard shortcuts are displayed when you hover the mouse over the corresponding button for a moment. You can also use some typical Windows shortcuts.
Keyboard shortcuts / key combinations in AquaSoft YouDesign
Page editor vertical scroll:  Shift+Mouse wheel
Page editor horizontal scroll:  Mouse wheel
Change zoom in page editor:  Ctrl+Mouse wheel
Maintain aspect ratio of the object when resizing:  Shift+Mouse move
Maintain center of an object when resizing:  Alt+Mouse move
Windows keyboard shortcuts / key combinations
Undo action:  Ctrl+Z
Redo action:  Ctrl+Y
Copy:  Ctrl+C
Cut:  Ctrl+X
Paste:  Ctrl+V
Delete:  Del
Select multiple elements: hold down  Ctrl  and click on elements
New project:  Ctrl+N
Open project:  Ctrl+O
Save project:  Ctrl+S
Save project as...:  Shift+Ctrl+S
Help/Manual:  F1
