Program overview
Navigation:  Program overview
Program overview
The structure of the surface
After starting the program you will see this view.
Program overview
Program overview
Use the colored Menu bar on the left edge to select your work step from the Start, Edit, Output areas.
Next to it is the Toolbox with all the tools available for the currently selected menu item.
On the right you will find the Page editor, the workspace, and below it the Page overview.
The Menu bar
YDPB_Btn_Menu
Create new project, Open project, Save project, Save project as, Archive project, Exit program
Call help, program info, search update, change license
YDPB_Btn_Project
Select template, customize template or make settings for own template
YDPB_Btn_Images
File browser, from which images are dragged to the page editor, and image tray, for bookmarking images
YDPB_Btn_Elements
Decorative elements for use in the Page editor
YDPB_Btn_Backgrounds
Full-page background designs for use in the Page editor
YDPB_Btn_Layouts
Image arrangement layouts for use in the Page editor
YDPB_Btn_Effects
Effects for photos, decorations and text elements for use in the Page editor
YDPB_Btn_TextStyles
Text objects for use in the Page editor
YDPB_Btn_Export
Project output
YDPB_Btn_Settings
Activate/deactivate language settings, hints and dialogs
YDPB_Btn_Collapse YDPB_Btn_Expand
Minimize/maximize the Menu bar
The Toolbox
In the Toolbox you will find the tools for creating your photo book. The detailed descriptions of the tools can be found in the following chapters.
For the tools Images, Elements, Backgrounds, Layouts, Effects, Text styles you will find a slider at the bottom of the Toolbox to change the zoom level of the Toolbox.
With Search and a keyword you can search the respectively opened Toolbox. Click on the crossed-out circle symbol to remove your search word. You will then be shown all the selection options again.
The Page editor
In the Page editor, you can see how images and text are arranged on the book pages. The Page editor is your workspace for placing objects.
Move images, backgrounds, decorations and texts to the desired position. Use the handle points on the objects to zoom in or out. Arrange your images using image layouts and apply image effects.
Btn_Undo
Undo last action (can be executed multiple times)
Btn_Redo
Restore last action
Btn_ZoomInOut
Reduce page view / Enlarge side view
Btn_ZoomFullSize
Zoom page view to full size
Btn_View_new
Activate/deactivate display of bleed, crop marks, center lines
Pro version Show/Hide Ruler, Show/Hide Custom auxilliary lines
Btn_Grid
Enable/disable snapping to centerlines, page margins, rotation grid, bleed, elements.
Pro version Enable/disable snapping for Custom auxilliary lines
Rulers
Toolbar with top ruler
Rulers Pro version
In the Pro version, the Page editor is bordered by rulers on the left and top. You can show/hide the rulers at the Grid item.
Custom auxilliary lines Pro version
To use your own auxilliary lines, drag an new auxilliary line from the ruler while holding down the left mouse button. Auxilliary lines can be dragged from the horizontal ruler as well as from the vertical ruler. The custom auxilliary lines are displayed in blue in the Page editor. Custom auxilliary lines can be moved with the mouse in the page editor. To do this, move the mouse over the auxilliary line until a black double arrow appears, then move it while holding down the left mouse button.
To remove a custom auxilliary line, click it with the right mouse button.
Tools for object alignment and mirroring Pro version
You can use the following tools to align objects on a page or spread.
Btn_Alignment Btn_AlignToPage Btn_AlignToLeftPage Btn_AlignToRightPage
Alignment: Align to selection / Align to side / Align to left side / Align to right side
Btn_AlignLeft Btn_AlignRight Btn_AlignTop Btn_AlignBottom
Align left / Align right / Align top / Align bottom
Btn_CenterHorizontally Btn_CenterVertically
Center horizontally / Center vertically
Btn_AxisCenterSelection Btn_AxisCenterPage Btn_AxisCenterLeftPage Btn_AxisCenterRightPage
Mirror axis: Center of the selection / Center of the page / Center of the left side / Center of the right side
Btn_MirrorVertically Btn_MirrorHorizontally
Mirror vertically / Mirror horizontally
You can find application examples for Change alignment and Mirror in chapter "Layouts"
Objects in the Page editor
Right-click on objects in the Page editor to find more functions.
Editor_Settings
Properties - changing properties of the element
Editor_Crop
Edit crop - crop image or change image crop
Editor_Cut
Cut - cuts out the selected element
Editor_Copy
Copy - copies the selected element
Editor_Paste
Paste - inserts an element from the clipboard
Editor_Delete
Delete - deletes the selected element
Editor_Placement
Placement - change the arrangement of the element
The properties of an object can also be opened by double-clicking on an element in the Page editor.
Page overview
In the lower Page overview, click on the individual pages or the book cover to edit them in the Page editor. With the icons on the left edge you can add or remove book pages.
Doppelseite hinzufügen
Inserts a new double page after the selected one.
Einzelseite hinzufügen
Inserts a new single page after the selected one.
Seite duplizieren
Duplicates the selected page and inserts it after the selected one. In the next step you can enter the number of copies.
Seite löschen
Deletes the selected pages.
