Operation via the keyboard
Navigation:  Program overview
In AquaSoft YouDesign you can also access some functions via the keyboard. Many keyboard shortcuts are displayed when you hover the mouse over the corresponding button for a moment. You can also use some typical Windows shortcuts.
Keyboard shortcuts / key combinations in AquaSoft YouDesign
Page editor vertical scroll:  Shift+Mouse wheel
Page editor horizontal scroll:  Mouse wheel
Change zoom in page editor:  Ctrl+Mouse wheel
Maintain aspect ratio of the object when resizing:  Shift+Mouse move
Maintain center of an object when resizing:  Alt+Mouse move
Windows keyboard shortcuts / key combinations
Undo action:  Ctrl+Z
Redo action:  Ctrl+Y
Copy:  Ctrl+C
Cut:  Ctrl+X
Paste:  Ctrl+V
Delete:  Del
Select multiple elements: hold down  Ctrl  and click on elements
New project:  Ctrl+N
Open project:  Ctrl+O
Save project:  Ctrl+S
Save project as...:  Shift+Ctrl+S
Help/Manual:  F1
