Repeat presentation endlessly
Navigation:  Control of the presentation sequence
Presentation end settings
In the Toolbar you can open the Project settings via the Settings button. Alternatively, you can also open the dialog via the Project / Settings menu. Under Flow / Presentation end you can activate the repeat function.
If you create a video DVD or Blu-ray from your project, this feature will be lost.
