Create your own random selection for transitions
Navigation:  Fade-ins and fade-outs
Selection for random transitions
 Ultimate   Stages
Under Project / Settings / Transitions you can make a preselection of transitions. This selection will be used for all objects for which you have selected the option Random as transition. If you want to save this selection for all future projects, press the arrow button at the bottom left.
Random transitions are generated with new random properties each time they are played.
You can also use the "Specify random transition" scriptlet let to have such a random selection fixed in the project.
Selection for an image
Own random selection for an image
If you want a specific object to have its own random selection, go to the Transition section under Object settings. Here the Random option should be set. Now click on the Adjust button. Here you can compose an individual random selection that will be used only for the particular image.
