Creating a CD image for the PC
Navigation:  Export a project > Menu Wizard > How to
Settings for PC Menü
If you have created a menu you can create a CD image which you can later burn yourself. CDs, that you can burn with the image can be replayed on your PC.
1 Load or create a new menu. Click on the "Project" entry on the left side of the Menu Wizard window in the project tree.
2 Click on the "PC menu" tab. Here you can make settings for the export.
3 In the "Window" section, select one of the preset resolutions or enter your own resolution.
If you want to play back the menu later, the resolution set here will be used. Activate "Show hints for buttons" if a hint about the function of a button is to be displayed later when the mouse is moved over it.
4 Click on the button TBr_Export.
Select PC menu
Select PC menu
5 Select the output format "PC Menu" and click "Next".
Create CD-image (ISO)
6 Uncheck the box “Burn project” and select the checkbox to the left of the drop-down menu.
From the drop-down menu, select “Create CD-image (ISO)".
Enter the destination file and click "Next”. The Menu Wizard will warn you if you have specified an existing ISO file.
7 The Menu Wizard is now ready for the export. Click on the “Export menu” button.
8 Upon completion of this export, click "OK".
