How to
Navigation:  Export a project > Menu Wizard
How to
Here is a series of instructions that working with the Menu Wizard will make easier.
Read here how you
Create a simple menu
Create a menu with separate chapters
Apply templates to the project and subchapters
If you have designed a menu, you can burn it:
Burn a menu for playback on PC
Burn a menu for playback with a DVD player
In addition, you can also use one of the other export options:
The exporting of a menu into a folder
The archiving of a menu as a ZIP file
Producing a CD-Image
Generating MPEG files from the projects and templates used
Generating VOB files
