Exporting a menu to a directory
Navigation:  Export a project > Menu Wizard > How to
Settings for PC Menü
Once you have created a menu, you can export it with all the projects and images used to a folder and burn, archive or view it later.
1 Load or create a new menu. Click on the "Project" entry on the left side of the Menu Wizard window in the project tree.
2 Click on the "PC menu" tab. Here you can make settings for the export.
3 In the "Window" section, select one of the preset resolutions or enter your own resolution.
If you want to play back the menu later, the resolution set here will be used. Activate "Show hints for buttons" if a hint about the function of a button is to be displayed later when the mouse is moved over it.
4 Click on the button TBr_Export.
Select PC menu
Select PC menu
5 Select the output format "PC Menu" and click "Next".
Copy project to a directory
6 Uncheck the Burn Project checkbox and check the checkbox to the left of the drop-down list.
Select the "Copy project to a directory" entry from the drop-down list.
Activate the "With Player" checkbox if you want to copy the Player for the menu in addition to your project.
Activate the "with Fonts" checkbox if you also want to copy the fonts that your templates use.
Select a destination folder for the export and then click "Next".
7 The Menu Wizard is now ready for export. Click on the "Export project" button.
8 After finishing the export, click "OK".
