Music settings
Navigation:  Inserting sound and music
Music settings
You can access the music settings via Project / Settings / Music settings.
Dlg_DSSettings_Music
The Music settings can be set as desired for each project. Shown are the default settings.
Activate background music
Allows you to specify whether or not background music should be included in your project.
Automatically repeat track list
Here you can specify whether the track list should be repeated when all tracks have been played and the presentation is not yet over.
Edit track list
This button will take you to the Background Music menu where you can remove or add tracks.
Default volume
Here you can set the volume at which the tracks should be played (100% = full volume).
Fade background music from project end
The background music can be faded out smoothly after the end of the presentation or simply canceled at the end.
Fade-out duration
Here you define the length of the fade-out. The fade-out takes place when other objects with a sound (such as videos or audio comments) are played at the same time.
Fade volume
If you use Sound objects in your project or have spoken comments on your images, it makes sense to dim the background music when playing these objects. Here you specify to which volume the music should be dimmed.
0%        = fade completely
100%        = do not fade
Fade duration
Sets the time period over which the music is to be faded.
Fade-outs also for sounds and/or video sound among each other
Here you specify whether the background music fade settings should also be applied to Sound objects or video sound running in parallel.
Live presentation mode  Ultimate   Stages
If this option is enabled, the music will continue to play during a pause.
Btn_DefaultSettings
If you want to save the settings for all other projects you will create, click on the arrow at the bottom left. This allows you to set the selected settings as the default for all upcoming projects. Alternatively, you can reset all settings to the factory defaults here and then confirm them as the new default.
