Control randomness
Navigation:  Control of the presentation sequence
Control randomness
Various templates in the program are based on random values, e.g. the division of a layout. To avoid getting a completely different layout every time you play it, you can put a stop to the randomness.
Randomness is repeatable
Whenever such an input field is present, the randomness is controllable. If the value is set to Automatic or if the question marks are activated, completely new values will be determined randomly each time they are played. To specify a certain combination, click on the dice symbol. This will result in a combination of numbers and letters such as "35A054D4EC16568E". This is the DNA from which endless creations can be made, and the same ones every time. Such random DNA can be copied and thus transferred to other objects. But only in case of similar objects (e.g. two photo collages) something similar will be created.
Please do not enter arbitrary numbers yourself, otherwise it may happen that not enough variations can be created from them.
In AquaSoft Stages you have the additional option to set a random value for the entire project under Project / Settings / Sequence.
