Use your own photo as background
Navigation:  Backgrounds
Photo background
Own photo as background
To use your own photo as a background, double-click the background in the Page editor or right-click the background in the Page editor and choose Properties. Using the folder icon, select the image for your background from your files.
You can also use a photo as a background by dragging the image to the desired page in the Page overview.
Use the slider to change the opacity of the background image to make your image appear as a slightly or strongly transparent background or with full opacity.
To remove the background image, click the cross icon to the right of the folder icon.
